86 4.6
roachedone
The gauges are all from the 04 gt.. I basically cut up the cluster and reshaped it to fit in the houseing of the 86... they are all the electronic gauges, and even uses the electronic control board from the 04.. I plan on pulling them back apart over the winter to fix a couple minor issues, so maybe then I'll be able to give you some more info..
coryjones
Got another question you may be ale to answer. Where is the millage stored in the cluster or the ecm? Do you know if there is a way to reset it? My 86 is a complete nut and bolt restomod and would like to set it to zero.
It is stored in the cluster. The reason I know is because we had a new one that the speedo didn't work right. When the dealer ordered a new one, they had to tell the mfg what the mileage was, and it came preset...three times.
