Sweet. I like the plug index. Very nice detail that is often overlooked.Today i got the new Manley valves installed in the heads. They fit, and with a minimal grind on the valves, they sit nice and deep in the seats. I checked the intake valves clearance to the deck of the heads with my piece of aluminum flat bar, and it looks like about .105". With the factory valves, the clearance measured about .068"... so i've picked up .037"! Going back to my measurements from a previous post where i found .028" PTV clearance on the intake valves at 8 degrees ATDC, i'm hoping that measurement will now be about .065", which would be within spec.
Since the block and heads have been sitting (even though covered in plastic) for a couple months, i'm going to remove, clean and oil the pistons and bores tomorrow before i reassemble and degree the cams... hopefully for the final time!
Here are a couple photos of the new valves installed, and the intake valve to head deck clearance (valve droop).
Fingers crossed, eyes crossed... ...regards, kevin
