No its just a GT sway bar
Is that a fox body sway bar or a new edge sway bar?
its from a 01-04 GT car.Is that a fox body sway bar or a new edge sway bar?
Did it bolt right up for you? Which mounting brackets did you use?its from a 01-04 GT car.
no it was a little funky it may not work or it might work great will have to drive it to find out. I figure a man could redrill the holes wider and it would work great, i used the factory brackets on the 01 up bar and the factory mount holes on the fox.Did it bolt right up for you? Which mounting brackets did you use?
Was re-reading your thread here again. Are you running a the stock computer with this dizzy setup? How hard was the wiring?
yes i am planning on running the mass air EEC ( A9L ) the wiring is a stock 5.0 harness that was very easy to mod, had to change a couple of plugs out and extend some wires but it was rather simple. When i get the computer i suspect i will have some issues, hopefully nothing major though. Im not gonna run any power adders such as juice or turbo, so the base timing should be just fine for me.Was re-reading your thread here again. Are you running a the stock computer with this dizzy setup? How hard was the wiring?
	Oh yeah trust me i want one BAD but hate to pay a shit load of money for one, im sure if i will be patient i will find one thats a reasonable price, as of now the headers im running should make up the loss in HP for the intake but i will find one eventually.Nice! I gotta talk you in to doing the cobra manifold swap! You're leaving 20-30hp on the table.
I may be wrong but arent mach heads " C " heads. Im running " B" headsI see Mach 1 intakes go for 350-400 complete on ebay. They flow more than the cobra intakes. I paid 400 for mine and it was brand new.
yeah i thought so lol. I will evenyually get get a cobra intake but its not gonna keep it from running, i get one later lolYou are not wrong. A mach 1 intake is not a direct bolt on for B heads.
i will stick with what i got for now lol but thanks for offerSorry i missed the b-head part. I have an extra set of c heads
