yepI am running a stock 03/04 cobra air intake. After I clearanced the hood, my shut no problem!
Is it rubbing on your bbk cold air intake?
I was actually looking for a stock tube but coundn't find one so I picked it up off the bay for 125 bucks, i thought i coundnt beat that. Since they are 349 newJust had to be fancy didn't ya lol!
OK it is apparent that the hood will not close even if i do gut the underside, so im gonna sell the BBK CAI and get a stock tube, i just cant bring myself to run a cowl hood on a coupe, I REFUSE LOL. so if any one needs a 03-04 BBK CAI hit me up would like my money back and thats it
I'm using the bbk on my mach motor. Clears no problem
96-98 or 03-04 there is a difference but i didnt think it would hit but i have been wrong before LOLI'm using the bbk on my mach motor. Clears no problem
trial and error is my moto LOL " if it aint broke then fix it anyways" LMAODon't say that around any girls you'll never live it down...
I put my proportion valve back in today it got dark and cold on me so maybe tomorrow I can see if it leaks. I hope not thought I might give it one more chance, if it leaks like hell this go around I'm gonna do away with it totally, I already put a adjustable on it just in case lol. Ordered my bassani down pipes for the mid lengths yesterday, maybe able to get the exhaust fabbed up in the next couple days. I'm curious to hear the bassani headers with BBK x-pipe and 40 series flow masters (freebies). Lots of parts on the way, throttle cable, stock air tube, only major part left to buy is a 8.8 don't think the 7.5 will work. Found out after some homework that the exhaust cams in a Mark VIII are the same as a cobra, the intake cams are the only difference between the two motors. You can pick up a set of intake cams out of cobra for about 150 bucks. Not bad for about 15 more HP.
Cams were worth 15-20 HP, no torque. I have them in my Mach motor. I have a stock manifolds, BBK h-pipe with cats, Flowmaster 2 chambers, 2.5 tails. Sound should be similar. 100% emission compliant btw 302 WHP / 302 TQ.
I broke a rebuilt (new clutches, bearings, 4.10's) SN95 rear with the above HP on MT 267 drag radials. So I don't think the 7.5 will hold up.
Embedded:
Forgive me because I'm a little confused, I thought you had an aviator engine with a Mach intake?
Also, what are 267 drag radials?
275/40/17 MT drag radial.
The Aviator Motor is identical to the mach motor (except it uses the GT rods) once the intake is swapped.
Let me clarify. The Mach 1 motor always used the Mustang GT rods which can be safely boosted to 450 WHP. There are people above that number but I question there reliability. Aviator motors are identical to the automatic Mach 1's once the intake is swapped. This means no forged crank, its the 6 bolt cast version. The cranks still hold up in a Lideo's (alternate performance) to 600 WHP The heads are identical 03-04 cobra/Mach 1.
